I presume they're 6l6???.. according to wiki...
I recently asked around since Sovteks have also 6l6-variants in them. This is from one amp-repair guy:
"On Tubes, you have multiple choices with the migs,
You can use EL-34's, I like the J/J and Electroharmonix EL-34's
You can use 6550's, My fav's right now are the Tungsol 6550's , If not them, then Svetlana 6550's
If you use 6L6, I do like the Sovtek wxt's and the 5881 wxt's.
On 12ax7's I like , the Electroharmonix 12ax7EH
the Tungsol 12ax7's,and the Sovtek's.
Do not ever buy the J/J 12ax7's. they suck, they are really dull sounding.
If you play more drop tunings, I like the 6550's they have great low end, great at concert levels.
The EL-34's are going to have the marshall sound, more distorted, great at club volumes.
The 5881/6L6 are smoother, less output, good low end.
I love Sylvania 6CA7's when you can find them, the new 6CA7's are not the same at all,
they are a great blend of EL-34's and 6550's, they have the smooth edge of the El-34 with the output and clean power of the 6550."
..I've tried 6l6gc:s and 5881:s and the russian 6p3c-e variant.
I didn't bias.
6l6:s sounded most open and bright, but was redplating in seconds.
5881:s were not far behind in sound, good thick bottom and mids. didn't redplate on Sovteks, did so on my Spetel amp.
6p3c-e... the original russian military issue, takes huge voltages and shaking, will not redplate ever.
...but sounds duller than the others.
EH 6l6gc, 6l6gc-e or wxt:s sound brightest.
5881wxt is tougher, sounds thick.
I'm getting a Novik mk120 amp tomorrow... god knows what's in there....
But as a "marshall-sound" fanboy, I'm trying EL-34 next, but up to this point the 5881 is my favorite.
