RecordingMaster
A Sarcastic Statement
Power conditioners into a "Home Theatre Surge Protector" into single wall outlet?
Sup holmies. Silly question for the day. While I may have taught myself how to solder a mic cable, I'm not the guru on electrical currents and the like (my dad came by and helped re-wire all the outlets in my new studio in progress).
What I've always done is had a "Home Theater Power Surge Protector" as like the main hub for all things being plugged that have anything to do with my computer, recording gear, etc. Basically to keep everything all the same place for easy organization, and because it even protects the things I don't have plugged into power conditioners (it has a little light on it to confirm if it's grounded properly and to confirm if it's still being protected or if it's been fried).
That being said, I plug all my audio equipment like monitors, AD converters, interfaces, mic pres, outboard, etc into power conditioners that have a degree of filtration (so they say) so as to not have any hums or buzzes or the like be audible in my gear when I'm using it. So for an extra degree of protection, I plug THOSE POWER CONDITIONERS into the "Home Theater Power Surge Protector", then that surge protector into one single wall outlet. So things like lamps (yes lava too!) and control surfaces and stuff that don't pass audio, but I still want to protect, go straight into the surge protector and not into the power conditioners first.
Anyways, as always I'm probably overthinking it, but for all the electronically savvy guys out there, do you think what I am doing is fine (it's not like I have a bunch of voltage hungry stuff all jammed in there, just a couple preamps and some other rack gear that isnt usually all on at the same time)? Or should I have each power conditioner plugged straight into a regular wall outlet and then the home theater surge protector into a different outlet?
Whaddya think/know/suggest?
