Hello all.
I'd love to know some tricks you may have learned or discover for using portastudios.
I currently have a Tascam 244 and a Akai Mg614, and I am quite happy with them.
I know some people like to record takes pushing a little the eq on the high side to prevent a later base or muddy mix.
Other things I've been doing is, having a two channel daw interface is to use the computer as a preamp, with effects and use, either the headphone or main outs to record on the portastudio, also monitoring from it. This way you can record a clean take on the computer, maybe for backup, and use some comp, delay or reverb plugins directly into the tape.
Only thing is , please,be very careful if you use the main balanced outs into your portastudio unbalanced inputs. You could fry the preamps and ruin a beautiful machine. So have a look at the meters and don't let them go too much into the red, just a little.
Also if your interface can deliver different mixes for the headphones, you could transfer a four tracks session from the computer to the portastudio, using the 2 main outs and splitting in mono the stereo headphone out. I am doing this with an Audient id22 and it is great.
Hope it helps somebody and would love to know some other tricks.
