I use one both direct, and as the Effects for mic'ing my amp. Seems to work for me, but am about an average player/ musician....HungPhat said:im Gassing badly and need to spend money.
so...
anyone use the POD XT for recording?
care to discuss??
i plan on getting one this week and getting all 3 model packs so when my firebox finally arrives i can actually start using my computer!
so...
care to discuss??
therage! said:That said, I have compared the V-Amps to the PODS and found them rather close in sound. I got the V-Amp pro because the POD just did not sound hundred's of dollars better.
HungPhat said:did you compare the v-amp to the POD XT???
i JUST sold my V-amp Pro and i still own a Vamp2
i chose the v-amp2 over POD version 2.0 but i have yet to have played the POD XT.
i will be using a combonation of mic'ing and using direct when recording.
HungPhat said:if i were to get an POD xt which would be the better way to hook it up to my setup
POD output to presonus firebox input
or
POD to USB port
therage! said:I use S/PDIF out to S/PDIF in on my Delta card.
Does the Firebox have S/PDIF? I would go that route if you can.
HungPhat said:pardon my ignorance but what is S/PDIf?
JazzMasterWil said:I was curious about this aswell.... How do you like your firebox? You do you think it was a pretty good buy?
HungPhat said:i know the vamp pro had that but ive sold it...
i only have the vamp2 which doesnt have it and i dunno if the POD Xt does either.
im pretty sure the Firebox has S/PDIF
wx3 said:There isn't a S/PDIF out on the Pod Xt, only on the Pod Xt pro. I don't find the usb out on my pod useful at all for recording, theres too much latency. I run it into the line in on my firepod and it sounds pretty good. The usb is good for controling and making patches on your computer for your xt though.
tourettes5139 said:*cough*search function*cough*
Sorry. Hairball.
therage! said:I use a V-Amp pro quite a bit. I've also got 4 tube amps I use and I believe modelers have a place in the studio. Normally I do like how miked amps sound in the mix but modelers can really take some work. The presets almost always suck bad so you have to spend time to create your own settings and that requires a LOT of experimenting.
A modeler can really come in handy when you can't crank up amps and you can always come back and record with your amps later. A lot of times I get an idea and I can quickly just fire up my modeler and get down my idea. I will always find use for them. But they still do not sound as good as the real thing and they probably never will. They are what they are, another tool to use.
