tsphillips
Please keep me from cutting my throat.
I have Cakewalk 9.
There is a button that is the Update control values to automation.
It seems to be stuck. I have tried everything I can think of to update to the settings I want.
But it keeps reverting back to some previous setting where the levels are on full and the pan is incorrect.
I will set it the way I want it, but when I export to .wav or .mp3 it uses the previous, wrong, settings.
When I go back in and put them where I want them and hit save it does no good.
I have …
Pressed the Update button and then changed the levels and pan while the file was playing.
Pressed the Update button and then changed the levels and pan while the file was NOT playing.
Changed the levels and then pressed the Update bottom both when playing and when not.
I have tried every combination of making the change and using the Update button.
But no matter what I do, when I hit play and then hit the Update button it jumps back to the WRONG settings!!! Arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh
This is not one song, it is ANY song. In fact it jumps back to the wrong settings the moment I press PLAY, only it does not look like it on the consol unless I hit the Update button, or click on a particular track, when it then reverts to the WRONG setting. In other words the visual does not revert but the soundtrack does, until I do something to the consol when it also updates visually.
HOW CAN I STOP THIS? HOW CAN I UPDATE MY SETTINGS SO THEY STAY WHERE I WANT THEM??????
Right now I have to paste into a new file every time I want to adjust levels. I don’t want to use a new file every time because I have to go in and set up all the tracks. I want to be able to do Save As on pre-existing files and use most of the settings. But it will not let me change levels and pans and update them so they STAY THAT WAY.
Please help before it is too late.
I have Cakewalk 9.
I have …
