K Knine704 New member Nov 5, 2004 #1 How do I assign sounds to my midi files using FL4 or Acid Pro 4.0? For example I have a drum pattern midi file and I want to assign certain sounds to it. Please help if you can Thanks
ssscientist Info you can use... Nov 7, 2004 #2 In FL4 go to the File menu, then to Import, then to Midi File. FL is supposed to work with either type of midi file - 0 or 1.
