Actually, NY style usually referred to adding a pumping compressor bussed from the ryhthm section tucked-in just under the mix to add depth and texture to the bottom.
I agree with Benny about the ambience. As a mix, it doesn't sound cohesive in terms of ambience or depth.... if you intended it that way, for a specific purpose, then fine -- but then you should probably mention that up front so that people who have ears don't have to point it out to you as a problem..... which it definitely is if it were a mix intended for end-user listening (instead of a producer-specific mix)........
