Pitch Correction & Quantizing in SF 6.0
  • Thread starter Thread starter beedub1
B
beedub1
Pitch Correction & Quantizing in Sound Forge
Does anyone know if you can set parameters for pitch correction in SF6 or 7? For example, is it possible to select a group of notes, or a scale, to "snap" or correct a vocal take? I'm singing in the key of A, can I correct the vocal pitches to match the key??? Along similar lines, is it possible to quantize drum beats, for example? Say a snare drum comes in a bit late, can I snap it to a determine quantized step?
Both cases are assuming independent tracks, so the vocal or the snare drum would be the only instrument on the track in the above examples.
Thanks for your help!
