O
oretez
Hwy 50
Have a friend with an Epiphone Chet Atkins SST. Acoustic Electric solid top piezo etc.
difficulty is buzz hum . . . volume of hum is proportionate to position of guitar's volume pot, frequency of hum is effected by tone pot.
all you have to do is touch jack plate and hum goes away
hum is less pronounced when jack is dangling loose from body (jack plate unscrewed) and what is no surprise is that by physically touching the ground wire (with a bare finger) the hum disappears
I can be wearing rubber soled shoes, be barefoot, be seated in a chair with insulated legs and have my feet off the ground, run through solid state amps, tube amps, change cables, etc. hum's there, touch jack plate hum goes away
in the course of trouble shooting ran through usual suspects, including replacing battery, replaced jack (primarily to check connections simply by resoldering them), and resoldered some connections at the pot preamp end of things (but did not pull piezo nor remove wiring harness entirely . . . while I can take things apart I have less skill with reassembly)
I tried using various configurations of jumpers from plate/barrel of cord to various parts of guitar, none of which eradicated hum . . . .though, again perhaps obviously, a jumper from jack plate to flesh did.
as my friend is not performing pseudo pierced punk the jumper to flesh solution isn't entirely satisfactory
so any suggestions that would keep me from having to rewire the whole damn thing would be appreciated.
thanks
thanks
