fuquam said:My mixer does not have phase reverse on it nor does my software (Logic Pro). Does anyone know another way to reverse phase. I think I'm having a polarity issue with my drum recordings.
Thanks.
fuquam said:Anyone else have this problem with Phase between snare and overheads?
How can you manually adjust it? Am I looking to line up the spikes?
here's the way I look at this,fuquam said:Wow thanks. I didn't know it was in Logic. I'll try that. Should I reverse phase on both overheads or on the snare because thats where the conflict is I beleive? Anyone else have this problem with Phase between snare and overheads?
Thanks for the link to the Shure gadget? I never knew those existed. I'll have to hunt one down. Or two depending on the answer to question 1.
Never had a problem with phasing between snare and OHs.fuquam said:Wow thanks. I didn't know it was in Logic. I'll try that. Should I reverse phase on both overheads or on the snare because thats where the conflict is I beleive? Anyone else have this problem with Phase between snare and overheads?
Don't stand in the same place for every overdub. Maybe use a couple two mics and do every overdub in a different place in the stereo field.DavidK said:Hi kids,
when I overdub a zillion violin parts, I get the obligatory phasing problems. I know why, but is there anything I can do to minimize this??
I curious, what is it that leads you to say it's a phase problem?DavidK said:Hi kids,
mixsit said:Uh, has anyone noticed that in this thread the op (and some others) have mixed time alignment and polarity as having the same meaning?
I often write phase invert for polarity probably because I don't think about it when I'm writing. If someone writes Reverse Phase or Phase Invert I know what their referring to without hesitation.mixsit said:Uh, has anyone noticed that in this thread the op (and some others) have mixed time alignment and polarity as having the same meaning?
