Phase Problem?
  • Thread starter Thread starter Ziller
Z
Ziller
I think this is a phase problem, but not sure. I have 3 dynamic mics that I use to mic my small 4 peice drum kit. I've found that I like the sound when I put 2 behind the kit, at ear level. I try to distance each from the snare the same amount, one pointing at the floor top/ride, and the other at the snare/tom/hi-hat area. I don't use a crash. I stick one in the kick drum. Right now I'm working on getting a fat floor tom sound, and it sounds great with the 2 rear mics. But when I bring up the kick mic, the floor tom start to sound thin.
Now, I remember that great graphic the John had put up a while back (which is no longer there), but what I'm not sure about is, if it is a phase problem, would it be because the mics are pointing in opposite directions, or because the kick mic is picking up the bottom head of the floor tom? I guess what's confusing is, when sound leaves the drum head, doesn't it travel out in a circle?
Would this cause phase problems:
mic mic
drum
This is what I have:
mic
floor
tom
kick dr.|
mic -- |
inside |
I could see if it was a speaker, with one mic behind and one in front.
I'm going to wire one of the phase reverse cords and see if that helps (switch pin 2 and 3, right?).
Ziller
Thanks for both of those tips! If you consider the bottom head of the floor tom as the source then, yah, I certainly break it. The mic in the drum is about 4" away from the batter:
[ code ]
mic -- |
[ /code ]
(just had to try it :)
and the floor tom sits less then a foot from the kick (but that's common enough). But the top head is certainly more then a foot away.
I suppose I could try sticking some sort of sound barrier between the kick and the floor tom.
aahhrrggg...let's try with no brackets...
code
mic -- |
/code
So I made a phase reversed cord, and used that on the kick drum mic and WHAT A DIFFERENCE! Now when I bring the kick drum into the mix, it totally *boosts* the sweet sound of that '72 Gretch floor tom. I'm not gonna put any thing between the kick and floor tom. It sounds great!
Now if I could only figure out those ascii code tags...
Ziller
OK, Hint 3: Remove the spaces before and after the bracket. My fault, I thought it was obvious, I'm a IT consultant.... :(
Hint 4: See where it says "vB code is ON" above? Press it. :)
Great that you got a good sound now!!
