Here were some confusing posts to me in sequential order from THIS thread:
I did some googling, found info that mentioned it, but can someone first give me a basic idea of absolute polarity, and the practical consequences it may have while doing micing, tracking and overdubbing? I was under the same impression of the middle three posts.
Thanks!
Even if you aren't reording with two mics at once, what if you are doing something like layering tracks? You are still better off to reverse the polarity to keep things in proper relationship. I guess a better question is why not reverse the polarity?
Wouldn't reversing the polarity take to take actually have more of chance of screwing up phase than just leaving it?
I'm having trouble understanding why you would do that.
No.
If you are only using one mic per take you never have to worry about phase.
A mic can only be out of phase in relation to another mic. If you are only using one mic at a time there is no way it can be out of phase whether you are using the front, back or side.
I don't see why this would be a good thing. When adding a layer, it's an entirely new track, I've never heard of reversing polarity of a new track like that just because it's 'safer'.
I don't think "safety" has anything to do with it.
Some people believe that absolute polarity is important. In other words, if the first pulse from a drum hit is a compression, they think that it is important that the same is true of the first pulse that comes from the speaker when that sound is reproduced. I don't necessarily accept that position, but that's the viewpoint that would argue in favor of carefully maintaining polarity on a ribbon mic - even when it is the only one in use.
If absolute polarity doesn't matter to you, then the only time you need to worry about polarity is when multiple mics are capturing the same source.
Thanks!
