leavings said:
Some of the pages have just a small amount of text that requires scrolling to be seen. I would try to shorten up the text by one or two lines to avoid scrolling pages where you don't need them. There also seems to be a lot of blank space below some of the text which has the same effect.
Site looks great though; professional appearance and fairly easy to maneuver through.
I believe the page was configured for screen settings of 1024x768 which looks good with default browser settings. However, if you've added anything to your browser menue or button bar (like some of those chat programs do) then it might send the format off a bit causing scrolling to be needed.
There's some code you can add to your main page that will check the user's current screen settings then load a different set of pages (that's if you want to do the extra work). Here's what I did for my old page (offline now---getting an overhaul)
User types in URL and my index.htm loads
∙ index.htm checks screen settings; finds it's 1024x768 and loads \1024\index.htm (index.htm also returns the user back to the page they linked from)
∙ \1024\index.htm is configured to open in a new window that is "stripped" it has no menu bar or button bar - it's optimised to use all the screen space. Window is maximized by default. And is forced to have focus (puts it on top - but only till the user decideds otherwise)
∙ When user decideds to leave site they can either click the X in the corner to close the window, or click the "close this window" text that appears on every screen.
∙ User clicks "Close this window" and is returned to the page they linked from.
Once I'm done fixing my site up some I'll show you what I mean.
- Tanlith -
