crazydoc
Master Baiter
I can't see that you're going to do any more damage by putting in a new fuse, old tubes, and firing it up - just flip the switch on and off to start with. If no popped fuse, switch it on until the tubes glow and see what happens.
If it works like it did before the tube switch, you're good to go until you can have someone work on it/ put in new tubes.
If the fuse pops, or it still doesn't make sound, then the problem is deeper seated, and someone with knowledge needs to work on it.
