thecugga said:
thanks for the input frederic
you're welcome.
thecugga said:
and just for the record i dont know why i listed egg cartons (maybe because i saved huge piles of them up in the summer, although after learning abuot recording on this website for the last half year or so ive realized that they do nothing and wasnt even planning on using them).
I figured the reasons were that you had access to the egg cartons, and thought maybe they'd be at least minimally useful. That's why you ask questions, right? You know the old cliche... the only stupid question is one that is unasked.
thecugga said:
i was just trying to make the point that, i agree doing it right could improve the sound in the room from say a 3 to a 7 ... but if i can change it from a 3 to a 4 then im happy.
I wasn't suggesting going after ideal. If I was, I would have suggested by far more than some rigid fiberglass in wooden frames stapled together. I would have instead suggested specialized construction techniques and harped on you about how mass in your structure is how to make a good recording space. You said you were on a budget, so I attempted to balance that with making an "okay" recording space. Rigid fiberglass, as an example, would help you achieve that.
thecugga said:
mounted with a pine frame and fabric. i have literally no money. first i gotta get me a decent pair of montiors
... but next on the list i plan on making a decent amount of these fibreglass treatments. i love the idea and think you could make a room look pretty killer with these things mounted on your walls.
I have a suggestion, and it might be a bit far out for you.
Instead of purchasing monitors, and acoustical treatments, why not buy some inexpensive direct boxes, and rent monitors?
Even in a crappy room (acoustically) often you can mic drums close enough with a noise gate that you can clip off enough of the room to get by. Record the bass, synths and so forth using the direct boxes (if you have multi-track capabilities, you only need one direct box BTW, but I don't know what gear you have, if any), and for the guitar, you can typically rent a POD or other amp/cabinet/speaker simulation device and plug that directly into your mixer as well, and record that. MIght take some fiddling to get the EQ and levels correct - the settings would be different than with microphones regardless of price range, but you've stated you're broke and fiddling time is free, right?
Before I facilitated my gear-slut-ness I did a TON of multitracking with headphones, homemade direct boxes, and other such flimsy crap. And it worked out well enough for me.
Direct, eliminates the room for the most part.
Wait, I suggested mixing with headphones, and industry no-no. Well, it's difficult, but you mix with the head-cans down to stereo to tape, then pop that tape in your parent's stereo in the living room, a boom box, a car stereo (factory and aftermarket), and so on. While you listen on each playback device you keep track of where the mix needs help, and then you try to adjust it a bit in the mix, back down to stereo, and repeat until you get it. Might take 2 tries, might take 5. Maybe even 20. But that's free
thecugga said:
thanks for the advice tho frederic, i do agree with you, and i really dont plan on attempting any major treatment whatsoever until i can do it properly.
I just didn't want you to spend money, only to be disappointed.
