Todzilla
Been fiddling around with this technique in which you compress the living hell out of drum bus, record that to a stereo track, then blend the uber compression in with the regular uncompressed drums.
Gives a good punch and sounds great, but one finding:
I find that I have to exempt overheads and room mics from the uber compression. Why? because it boosts the hell out of the hi-hats. The drumming performance in question is a great drummer quite skilled in hitting the drums hard and cymbals gently. The uncompressed drums are very drum heavy, with just a little hi-hat. But the uber-compression brings out the grit and grain of the hi-hats like nobody's business. Once I exempt the OHs and room mics, the resulting NY Compression works great.
Is this normal?
Is this normal?
