Mastermindzz
I'm running Nuendo and Cubase SX with a Delta 44 and when I open up either program, I get the message sample rate can not be set, interface may be set to sync external clock. The only drivers I am using are the Delta ASIO Drivers which gives you the only choice of setting sample rate through m audio mixer. The sample rate is locked at 48 khz, clocked internally. When I set markers to export a track done in either program, I get an error log for Cubase or Nuendo and can not export the file to save it as a wav. I have been working at this for a week now, and it's set up on a VIA chipset with a celeron processor which will be replaced Friday by my new Athlon system coming in the mail. Anyone ever experienced this problem ????
