Carny1122
Plugin Whore
Hey guys, so I've run into a bit of a dilemma. I'm starting a new project with some buddies this Saturday, but I have a micing dillemma. I've got an old school *original* Firepod, using Logic Pro 9 as my DAW. I've only got 8 inputs. I need 12 for the drums (2 on snare, 2 on kick, 4 toms, hats, 2 OH's, 1 room). As far as I've been able to come up with, here are my immediate options:
1: Buy a second original Firepod used for about $200, give or take $50; daisy chain this into the first one, giving me 16 inputs. Sounds good.
2: Buy an ADA 8000/Digimax FS/8 channel ADAT preamp unit and borrow my buddy's Motu 8 Pre, lightpipe the ADAT pre into the 8 pre, 16 channels. Voila.
Here are the problems/cons that I've come up with for both.
1: If I buy a second *original* Firepod, I've then got not one, but TWO older interfaces to worry about getting rid of within the next two years or so. I doubt I'd even be able to sell the pair for $200 two years from now, and I'd rather not get stuck with them.
2: If I buy an 8 channel ADAT pre, I can't use it with my Firepod (no ADAT in/out), so I'm stuck with an 8 channel ADAT pre that I can't use whenever I want to.
What would you guys do? Right now, I'm leaning more toward the second Firepod, even if I end up "stuck" with it in two years or whenever I upgrade. I've found a few at GC's and the like for around $200. Push comes to shove, I'll go 8 mics on the drums (1 snare, 1 kick, 4 toms, 2 OH's) and use Logic's replacement to replace the snare and kick sound and put on a decent room 'verb after it's said and done. Right now that's the cheapest option, too...
Thanks!
Thanks!
