M
MercyfullMusic
Ok, here's the deal. I have Sonar, the Delta 1010, and a small 8 input Behringer mixer. Pretty decent stuff. I was trying to record drums for the first time the other day, and although I set the gains on the mixer to be as hot as possible without clipping, my level on the tracks is low and visually the waveform is small. I normalize, but again it is still pretty low.
So, I think the real problem here is limiting and compression. My question is this...is the best idea to compress before (or as) you record so you get a hotter level? Would the ideal be to have some outboard rack stuff to send a hot consistent level in? Or can I do this just as well with Sonar's Compression and Limiting after it's already in the computer. The difficulty I have with the real-time effects of compression is that I can't see the waveform's change. I want to see the waveform really maxed.
I have messed a little with loops on CD you can buy and the drums kick you in the face!!!!! How can I get that type of level? I think it's a critical problem because it's very easy to mix loops whereas music at levels I have recorded it much tougher to mix.
FYI: I am using good drum mics so they are not the problem.
