... basically lots of popping, distortion and crackling.
Is anyone using the exact same combo? And if yes, experiencing any pops during playback/recording, specially during disk activity?
I have tried:
1. PCI latency settings in BIOS
2. ACPI/APIC disabled in BIOS
3. Non-overclocked setup
4. Full resintall
5. All drivers and BIOS on the web, in every combination.
The setup is an A7N8X deluxe, onboard SIL controller, 2 x 120 GB maxtors SATA drives, and the Delta 66. The Delta 66 is on a PCI slot where it is only sharing with 1 USB connection (all slots on the mobo share with something - Firewire, USB, RAID, onboard or AGP - that's the five slots).
The problem is absolutely not there when only using my venerable IDE drives. m-Audio support has explained its helplessness and has seemed to point to a full IDE-only setup as the way to go. Maybe I'm hosed, or I need to look at the Intel side of things, if any of you are succesfully running -
1. SATA RAID (Important!!) for the OS, audio programs, etc.
2. A Pro Audio card like a Delta 66
3. Overclocked setup - P4 2.4 or 2.6@3.0 Ghz or more. HT is not that important...
Thank you
I have tried:
4. Full resintall
Thank you
