lurgan liar
Jimmy Page XXVIII
Hey guys... Need a bit of help with compressing drums... I read this in the Mixing Engineer's Handbook... but i can't seem to be able to work out how to do it in Sonar....
Here is the excerpt from the book...
..."The New York Compression Trick
One of the little tricks that seems to set the new york mixers apart from everyone else is something i call the "New York Compression Trick". It seems like every mixer who's ever mixed in New York City comes away with this maneuver. Even if you don't mix in NYC, once you try it you just might find yourself using this trick all the time, since it is indeed a useful method to make a rhythm section rock.
Here's the trick:
1) Buss the drums, and maybe even the bass, to a stereo compressor.
2) Hit the compressor fairly hard, at least 10dB or more if it sounds good.
3) Return the output of the compressor to a pair of fader inputs on the console.
4) Add a pretty good amount of high end (6-dB at 100 Khz or so) and low end (6-10dB at 100Khz or so) to the compressed signal.
5) Now bring the fader levels of the compressor up until it's tucked just under the present rhythm section to where you can just hear it.
The rhythm section will now sound bigger and more controlled without sounding overly compressed. "....
My question is this ...how exactly would i do this in Sonar 5 ... i'm not sure if i should be using SENDS....and i don't see how it is possible to RETURN the output of the compressor to a pair of faders in the console ...
The only way i am able to do this is by SENDING a "dry" Drum Buss to the "compressed" Buss which i then SEND to the "EQ" Buss ...
Please Help...
Here's the trick:
Please Help...
