I have a daw i built about 3 or 4 years ago. It has a Gigabyte LGA1156 4DDR3-2200 CrossFireX/GBE/Raid/SATA3/USB3.0/7.1-CH ATX Motherboard GA-P55A-UD3 and an Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor. I am running Protools 10 and Windows 7. 4 gigs of ram.
I have been using an M-Audio Profire 610 and have had no real problems. I recently replaced my interface with a Focusrite Saffire Pro 40. Since then, some of the songs I had previously recorded and mixed are overloading my cpu, due to too many plugins.
First, why would the Focusrite cause a previously working session to now jam up? I know some settings in Protools were changed when I installed the interface software, but I don't see anything that has been changed that would use more processor resources. It did change the hardware buffer size to a larger amount and I don't seem to be able to change that, but I think that should take some pressure off of the cpu, not add more demand. maybe I am wrong about that. My cpu usage for native plugins on the song I am looking at right now is at about 55-60%. And that is with about 40 plugins running. I don't know if that is what is was with the old interface, I never had a problem and never looked at the system usage window.
And second, if I were to replace my processor with something different that works with my motherboard, which should I choose?
Here is a link to a list of processors compatible with my board:
GIGABYTE TECHNOLOGY Socket 1156 - Intel P55 - GA-P55A-UD3 (rev. 2.0)
While I did manage to build my computer, and didn't run into any problems with it, I am not that much of a computer geek. Is it simply a matter of the higher the number of the processor, the better performance I will get out of it?
At this point, I really don't want to tackle replacing the motherboard and all that that would entail software-wise. I do realize this is really limiting me in what processor I could upgrade to.
I have not used the Focusrite much yet, I am just starting to see how it works, etc. Have not recorded anything new with it.
Any help or suggestions would be appreciated.
