			BroKen_H
Re-member
I know that some will immediately knock this new tech because it takes musicianship away or because it's cheating, or some such...
But I just saw the videos on the new Propellerhead hypersampling project (so far drums, bass and piano).
They take multiple instruments, mic them with multiple (many, many) expensive microphones, at all velocity samples, in a great studio environment.
End result: you can use the instruments with midi (including extras, like glissandos, slides and ghost notes on the bass), mix it with whatever mics you want or don't want, change kits or amps or basses, change between three great grand pianos, and then get your mix down. And it will seamlessly integrate with other DAWs so that Reason is only a dedicated drum, bass or piano mix. It all looks amazing to someone like me who has 3 mics and no acoustic treatment.
Check Propellerhead - Reason Pianos
Propellerhead - Reason Drum Kits
Propellerhead - Reason Electric Bass
Got a kick out of the cockiness of the bass player in the vid, but this seems awesome to me. For less than the cost of ONE of the microphones ($300) I can get all these packages.
I realize that nothing (including these) will replace live drummers or bassists. It might get close, but it's just not going to happen. But I can play my piano using the midi out and play through a steinway or a yamaha 9' grand and have the use of 8 mics and a variable sized room. Who are we kidding, that's awesome. Also if you play through good quality drum triggers you may end up getting pretty good results there, as well.
But, seriously, do they think you can do guitar or bass fret noise/slides/pick noise/etc....with a midi?
