Hard drives are machines, and what do machines do?
Polaris20 said:
I brought probability into it, because probability is always a factor to consider when discussing hardware failure.
In my opinion, it's not something to be ignored, whether your talking about losing the song you wrote about your sweetheart on your home PC, or losing the financial records for your company for an entire year.
Sure, obviously one sucks more than the other, but they both suck.
they break. there is no probability in that. chances are 100% your hard drive will fail. the socalled mtbf numbers are calculated numbers, nobody has ever put 100 drives out of a certian model number on test beds and exercised them 24/7 for five years. they use a formula, but they might as well use a WAG.
I have seen both drives in a raid mirror fail within 24 hours of each other.
I think ontrack starts at 600.00 dollars to look at your drive and make an estimate. they are several hundred dollars an hour after that.
if your data is on a raid O, and one disk fails unrecoverably, I don't know of any way to get your data back. You can take the disk out in a clean room and go over every track you can get to, but if the heads have damaged the drive surface you are pretty much fucked.
if you have name brand drives, and you keep heat buildup to a minimum you up the odds but there are no sure things. I bought 4 IBM desk stars (ibm has now sold its drive biz to hitatchi) and all failed in under 3 years.
like gene wilder was told in blazing saddles "you keep drinking like that you gonna die".........he just looks at the speaker, long pause....."when?"
probability always enters the calculations if people are responsible for a room full of servers, or all the systems in a hospital. I mean, you allways know the salesman is lying to you, the question is 'how much?'
you are getting good advice here, even if it is not what you want to hear.
