I
ikijapan
Alright, so, I have an arrangement of a song that I am adding acoustic guitar to. There are already several other instruments in the song such as strings and piano, so what I'm doing with the guitar is just adding some small chords.
What I mean by that, is that a lot of the chords are just 3 string notes, up high on the guitar.
The problem I'm having is, when I play a small 3 string chord up high, and then later a bigger chord, like a 5 string A minor chord, it's much fuller, because there are open strings ringing on those, and not on the others.
How can I compensate for that? I hope this question makes sense.
I wasn't sure if compression would help here? I just want the higher up chords with no open strings, to sound as full as the 4 or 5 string chords. Is that possible by using some DAW tools?
Uh, also to clarify I am close micing the guitar on the neck. That is probably part of the cause of the smaller chords sounding thinner than the larger chords. I imagine if I backed the mic much further away that would make things sound more even in this case, but I want to AVOID doing that.
Thanks for any suggestions
