All,
I and my fellow band mates need to record 4 songs to submit to a local rock search contest. Since the entry is due by 10/01, we don't have enough time to record track by track and mix.
Our only option is to record the stuff live. Which is okay; all they need is to be able to hear you enough to know your worthy of entering the contest. It doesn't need to be studio quality.
I'm looking for advice on how to set up our equipment to get the best result.
We have:
-TASCAM US-122 (USB device, 2 inputs (mic or guitar), phantom power on both)
-PA system
-1 Condensor mic
-5 Schure mic's
- Recording area is a wide open basement.
Specifically
1. How would I get the best acoustics? Band on one end of the basement, mic's on the other? In the corners?
2. How should we mic the stuff. One idea we had was to use two of the Schure mics for the drums, and one for the vocals. All 3 of these would run into the PA, where we could adjust the levels somewhat, then run it into the Tascam. Then place the condensor mic in the middle of the 3 guitar amps.
If we took that approach, whe thought we'd seperate the drum kit from the rest of us, and maybe hang a large piece of carpet between us to shield the condensor mic from the drums.
Any advice is appreciated.
Thanks!
We have:
-PA system
-1 Condensor mic
-5 Schure mic's
Specifically
Thanks!
