Need some help from DIGI 002, 002R users
  • Thread starter Thread starter reshp1
reshp1
reshp1
After installing my US2400, my MIDI has become (I think) screwy. I can't remember exactly how my MIDI outs on the 002R use to behave, but I'm pretty sure something has changed. I was wondering if one of you could try a couple things right quick so I can compare and get a sanity check. First off, if you select an output on a MIDI track, does the 002R MIDI OUT's show up as "[Emulated]"? Also, if you're sending MIDI data out one of the 002 MIDI out ports, does the little light in from under MIDI out flash? Also, if you have a MIDI cable handy, can you plug the MIDI out into the MIDI in and receive the same data you're sending?
It seems as if all my MIDI outs have been changed to "Emulated" and none of the above (flashing lights, MIDI out into MIDI in) works for me anymore, but I just wanted to make sure it's suppose to, or ever did. Thanks for your help guys.
