SpotlightKid83
This is my 1st post.
I need help on setting up Battery VST so it plays different sounds depending on the velocity of the MIDI note. I do know how to set sounds on different layers, like for a snare, I can put 4 different snare sounds on the same cell but it will play all 4 at the same time on every hit. I've read one can set up Battery to play a different layer depending on the velocity of the hit, like if velocity is 0-50 it will play sample 1, if it is 51-80 will play sample 2, 81-100 will play sample 3 and 101-127 sample 4. This is to make the drum track sound closer to a real one.
Also if anyone knows how to route the output of each cell to a different track so it can be EQed, compressed and/or FX separately.
Thank you
Thank you
