octoruss
Hola amigos--
Yer friendly octoruss here. Haven't been around for a while, but it sure is good to be back at HR.
Ok, here's my question. I've got a bar gig coming up--the first one in about seven years. I play with one other guy and we do 2 acoustic guitar stuff and close harmony.
I just bought a Yamaha EMX660 powered mixer and 2 Yamaha S12 speakers anticipating that this will not be the last. But where I need help is a starting point for initial EQ setup.
As I said, we will have one mic for each vocal, and both guitars have fishman pickups. Each channel on the mixer has a 3-band parametric EQ, and a 7-band graphic mixer for the master mix, plus individual settings for the built-in reverb FX.
Since I'm somewhat of a dummy when it comes to EQ, can you suggest initial EQ settings for the guitars, vox and most importantly the master? I think it would be good to have different EQ settings on each so that nothing gets drowned out, but again I don't know where to start.
Thanks for your help! And if you need a view of the mixer, it can be found here: http://www.yamaha.com/menuitems/panelviews/proaudio/EMX660/EMX660.htm
