crystal_andersn
I think i'm confusing myself the more I read into this, but I'm trying to hook up 2 boss giga delays (dd-20) properly through a behringer 802 mixer's send/receive.
question 1: the tech notes for the mixer state the max output/input levels for the aux is +22dBu. should the output mode for the boss then be set for -20db (as opposed to +4)? the impedance range for the return is 20k(omega) balanced and 10k(omega) unbalanced.
posting in the noob section because i barely know what any of that means^ i understand line level vs instrument level but not necessarily how it pertains to the above items.
question2: the hookups. i run a mono distortion pedal before the 2 DD-20s as well. so its distortion pedal in and out to the first dd-20's mono input. then i run the stereo outputs (A + B) to the stereo inputs (A + B) of the next dd-20. and then only output B (effect) to the aux receive? i have the first dd-20 set up as output mode 1 (stereo output-20db) and the second dd-20 as output mode 2 (a:direct sound / b: effect sound -20db).
am i on the right track? i've had these configured many different ways and while none of them are technically wrong i am trying to get it the most correct.
for the rest of the chain i have the main outs of the mixer going into a yamaha thr10. side question - does it really matter if i'm going from the mixer to the amp through either the headphones (mono 1/4 jack) or the main outs (2 x 1/4 unbalanced jacks) or the cd/tape output (rca jacks)? i usually throw an h4n somewhere on one of those as well so i can record the feed before it hits the amp.
thanks for reading and in advance for your help.
