faderbug said:do they need to be filled? you can't see them.
TravisinFlorida said:you should probably try to find dowels made out of a wood with a similar hardness as the neck.
32-20-Blues said:Prob'ly maple. Yeah, that sounds good, but the drilling can go very wrong unless you have a drill press, which most people don't. You really don't want to ruin the neck.
Roybot said:Thanks for all of replies. I'm going to use an oak dowel and mix some wood glue with wood putty and work it into the holes so that the existing threads get filled along with the holes. I'll use a drill press for drilling the new holes. Thanks for that suggestion.
Light said:Don't use match sticks either (GADS!)
32-20-Blues said:That's cool, each to his own. Do you build / modify much stuff?
I put the necks in the central recess of a Black & Decker workbench before drilling so that they are held level. Works fine.
It's my understanding that this guy has holes in a neck and holes in a body that don't match. Therefore, drilling when the two are together won't help. First, he needs to fill the 'wrong' holes in the neck. Then he can clamp the 2 together and drill through to his repaired neck socket if necessary.
Roybot said:Thanks, Light! That was very helpful. I was hoping you would chime in. I will look for maple and ditch the wood putty idea. It didn't occur to me about the neck radius causing instability on a drill press platform. When I installed a Warmoth neck on one of my strats I drilled it by hand with no problem so I'll use the same technique on this neck. When I installed that neck I strung a low and high "E" string pulled to enough tension to use as a guide on both sides of the fretboard for aligning the neck prior to drilling.
