My plan for XLR/TRS/Phantom Power
  • Thread starter Thread starter incursio
I
incursio
Hopefully someone here with more knowledge than I have can confirm that my plan here will work.
I have a need to record 3 condenser mics. My Yamaha AW4416 only gives me 2 XLR/phantom power/pre ports. So I am stuck trying to figure out how to get that third mic in the mix.
If I buy a stand alone phantom power unit, like this one:
http://www.musiciansfriend.com/product/AudioTechnica-CP8506-4CH-Phantom-Power-Supply?sku=337501
Can't I basically buy (I can't make it myself) a converter cable to convert the XLR output into TRS, and run that into the balanced inputs 3-8 on the AW?
Thanks in advance!
If inputs 3 - 8 are microphone inputs, the answer is yes. If they're line inputs, you'll need preamps. A quick Google search seems to indicate that they are in fact microphone inputs, so you should be all set once you get the XLR to TRS cables.
Cool - thanks for the reply Don!
I'm no cabling guru, so I was a bit unsure.
Peace!
