Ok, I took another run at this mix this morning. 4 cups of coffee later, here is the end result.
http://www.soundclick.com/util/getplayer.m3u?id=6291775&q=hi
I tried to take all of the feedback into consideration. Heres the run down as to what I did (I actually took mixing notes.... there's a first time for everything I guess)
On the Drums:
On Both kick drum channels (no I'm not just doubling the kick - there is an inside position as well as an outside position) I reduced the 80k boost by 2 db
On Both Top & Bottom Snare channels I reduced the level by 1 db.
I also brought the crash cymbals down by about a db each.
I reduced the over all drum bus level by 1 db.
On the Vocals:
I pulled each of the chorus backing tracks down by 1 db each.
On the Guitars:
For the Rhythm Guitar I switched to vintage simulation with a tube compressor. This also seemed to my ears to bring out the mids a bit more, so it sits higher in the mix, so I didn't adjust the volume as I had planed to.
On the lead Guitar, again I switched to a vintage simulation and toned down the distortion. It was a bit too forward after that, so I added just a touch of delay to pull it back a bit.
I would greatly appricate any feedback on the new mix. Thanks guys!
Chili - Thanks for listening. I dig your new tune. I think I am going to supplement the truck test with the cheesy laptop speakers at work test.
