Strave
So every channel crackles a bit when sung into at loud volumes. (It's not clipping... it's a subtle like background crackle)
It's not the mic because I tried two.
It's not the preamps because there are 8 and it happens on every one and the brick does it as well.
it probably isn't the converters for the same reason ( I don't know much about converters though)
It's not the cables because I tried 3 of each type.
Mic -> cable -> preamp -> converters... the whole chain is covered so what could it be... and why would it only crackle when the vocals are loud? (again, it's not clipping)
Do you think it needs to be repaired?
Thanks for your help.
