Anomaly Design
Somethings very wrong with my Roland TD-10. I turn it on and the output makes constant feedback noises. The module itself is fine, all buttons and menus work, its picking up the triggers. When I hit a drum it kind of worked but now no sound is coming out except the horrid din of feedback. I hooked my amp up to each 1/4" output and received several shocks while doing so. I then turned it off and proceeded to curse furiously.
It seems to be just the outputs. If I press the jack in far enough the sound stops. Does anyone know whats causing this and if its possible to fix, or should I just send it to Roland to be fixed?
