dafduc
Here's where to read about the contest:
http://bluemic.com/contest/
Here's the Songwriting thread where I posted the lyrics:
https://homerecording.com/bbs/showthread.php?s=&threadid=96379
And here's the Singles page with the recording (look for Blueblue):
http://www.nowhereradio.com/graytail/singles
I'm not sure if I'm going to submit this version - could't figure out why the verb on the vocs was so weird, then realized it was probably getting processed before the (super) compression. So I really need to bus the vocs and put the verb on the bus, but the postmark deadline is Sunday. Talk about down to the wire...
This was my test of Autotune (demo version) - saved me a bunch of takes. A couple notes still sound out of tune - vibrato was probably so heavy the AT didn't know what to do with em. There are artifacts, but they aren't bothering me much.
The other thing I gotta admit is that either there's a timing problem with latency offsets in Acid - or else there's a problem with MY timing. Clav part kept sounding late, so far off that I couldn't quantize! Did about 5 takes. Finally, in desperation, I pulled the clav track up 1/32 note - that mostly did the trick.
Oh, and thanks to Harvey Mason and Paul Jackson for sitting in... J/K - bass & drums were freebie Cyclick tracks from Computer Music mag. Clav was freebie from BigTick, EP was Emagic's EVP-73. Tracks all built in Acid 4.0, then ported into Cubase 5.1, where I added vocs (compressed, tubed, and verbed), threw some EQ & verb on the EP, and limited the whole mix.
Interestingly, the supposedly full-featured Autotune demo seemed to prevent me from rendering the vocal track - When I did the Cubase render thing, the track came out sounding great - but with no vocs. So I used Sound Forge 6.0 to record the Cubase playback, then normed to -1db.
mp3 is at 128k, using realplayer's built-in --- I usually use CDex, but RP popped up, so I gave it a try.
There's a lot I wanted to do with this - background vocs (with Steely Dan style part swaps), horn lines, more clav work --- but I just had to do the "pencils down" thing and move on. The 3-minute thing was a challenge, too - had to cut some intro.
If I redo this (still undecided) I might drop the refrain before the bridge - Listened about 30 times (really!) on my commute this morning, I'm thinking more & more that nobody really needs to hear that refrain FOUR times. It'll mostly depend on how the verse-bridge transition works if I yank the chorus there.
The other thing I noticed on the drive was how great the EQ sounded - then realized after about 20 listens that I had my "jazz" EQ preset on my car stereo, which boosts highs & lows - when I went to flat it sounded a bit boxy.
Oh, and if you haven't listened to the scratch version of Toki & Daf's HRC4 collab (Lift) it's up there on my singles page too - final version promises to be way better, after Toki and his choir of angels are done with it...
Any & all feedback on Blueblue welcomed - especially advice about quick tweaks I can do between today and tomorrow.
Thanks in advance, guys,
Daf
Daf
