T
		tvolhein
Tom Volhein
Yep, large diaphragm condensor mic. 32mm.
Thanks again
			Yeah, I used the single sided CEK-89. 100% drop in replacement, as long as you can solder some very thin wires (about 28 gauge).
Definately the best $120 'addition' to my limited mic collection, I don't think $120 (above the sunk cost of the 960 itself) would have given me anything near as cool.
If your opening the mic to do this, look around for some old 12AY7's or 12AT7's. I know for sure you can find a Mullard 12AT7 for $30, great sounding tube that makes a very noticable difference as well on the 960. The stock tube is pretty well rubbish.
			Mullard is a brand of tubes made in Britain. Not a type.
This is important to know: All tubes sound different! Even tubes of the same batch from the same brand! You have to use your ear to find a good one. It should not produce significant levels of self noise and should not produce any harsh artifacts, especially in the high end.
Just buying an NOS tube is not enough. You have to personally audition each to get the right one. Even some Chinese tubes can be good so long as you find one that sounds good. There's a big misconception that all Chinese tubes are bad.
			Just a follow up on my intended mods, the only thing my 960 contributes now is just a chassis, body, and a power supply. I used a Jensen paper in oil capacitor, a Cinemag transformer, a GE 6072, and a few various resistors to make the mic. It's a loose interpretation of a U47, and it sounds really good! It took me a little bit to get the resistor values about right, I got it close enough to call it good. Vocals are much richer than they were with the stock 960 circuit, and somehow with the same Peluso capsule as before the detail is much more startling. There is a very large difference between the transformer and non transformer based version of this mic!
The mod is not for the faint of heart, the parts are gigantic and the mic innards are very compact. Fortunately, there are few parts, but they are bulky and hard to get positioned such that the case can still slide on. If anybody wants to do this and has the requisite skills, time, and patience, I'll be glad to share my work details with you!
			Hopefully some you will be as excited as I am when you learn OktavaMod will soon use Peluso capsules and transformers to augment my electronic modifications to Chinese microphones.
Tests are under way on the full line of John's capsules and transformers. I gotta say his re-creation of the BV8 - the "iconic" transformer pioneered in the U 47 is absolutely righteous. Powerful and punchy with deep dimensionality, gobs of headroom and best of all when used in a Chinese mic - reduces the hash / grit and spittyness so common in these mics. John told me it was a two-year odyssey to get his BV8HR right - including having a custom alloy blend made for the lamination metal.
Some of you know I used to work for and studied under the late Dave Blackmer, the founder of dbx Inc. and Earthworks Microphones for almost 15 years. Dave was a monster of his craft. As I've gotten to know John Peluso a bit better I can tell you there are still microphone giants among us.
Soon I'll have a suite of modifications for some of the "best prospect" Chinese mics. Stay tuned.
			If that transformer could be brought down to a 2:1 it would be killer in a lot of Chinese FET mics. I've got a lot of projects going on right now, but my next test is to try an Edcor 2:1 in some FET mics and upgrade the signal path. I tried them in some tube mics I am building and the results were very favorable. They are currently the only transformer manufacturer I can find that makes a 2:1. They have several sizes and the smaller ones work, although you have to ditch the MU metal can.
			Peluso has a line of five different transformers, two "BV8-style" units each with different core sizes...
			There is only one "BV8-style" transformer--the one of ORIGINAL core size and FOUR-CHAMBERED. Anything else is a marketing trick to cheat unaware customer. Hopefully, it is not your intention.
Best, M
			Hey Phil, I have a CNC winding machinery and make all the x-formers (including multi-chamber BV8 on original size core, from original blueprints) myself. I can make it with any ratio and specs you need, in any quantities, and on any EI, UI, or L core size you'd like... just let me know.
Re: BV8. I believe it is WAY oversize and overkill for use in FET microphones. It was designed for a huge voltage swing and headroom of VF14, which FETs cannot even remotely give. Friend of mine has a good expression--"you need to wake up the core". For the lower coltage swing of the FET based mics the core size of BV8 is just too big.
The fact, George Neumann had in his disposal BV8, but went to troubles of designing completely different x-former for U87 already speaks for itself.
IMO, it is a waste.
Best, M
			I don't mean to be argumentative at all...
but the original long body U47 had a transformer with a larger footprint that the one in the short body U47. Both were referred to as BV8. And as much as I respect your attention to detail and truth Mark, you're pulling a bit of a Klaus Heyne here. Michael and John P have both indicated that they are of BV8 "style" and have never implied they are an exact replacement as a BV8. Even Oliver Archut needed to have words with Klause because he feels his BV8 is as close as humanly possible to reproducing it. I believe in the end he conceded that it was not a direct replacement.
			I wish there were laws for protecting consumers and customers from marketing misleading tricks. But maybe that's only me... In any case I realize I might be in minority, as nobody ever seem to listen to what I say.
[:end of rant:]
Best, M
