32-20-Blues
Muttley, on my balalaika (as on all balalaikas), the bridge is very long. The 3 strings passing over it in the middle take up about an inch, but the bridge itself is about 6 inches long. Does this give it a characteristic sound? In other words, with a shorter bridge, would it sound different?
The intonation on the middle string is way off, so I'm going to make a new bridge and compensate it. Anything I should be aware of? Mahogany okay as a wood to use, maybe with a bone insert?
Also, any idea on what the action should be like on one of these? I'm guessing closer to a nylon string guitar than a steel string, right?
With regard to learning it, I'm making progress. I'm definitely not using it for what it's intended for, but it's all good.
Thanks man, you're a legend.
