philbagg
Just Killing Time
Hey guys, haven't been on for a while. Have an issue however (isn't it always the way )
Any help at all with this would be appreciated.
EDIT #1: Turns out the DV toolkit 2 crashes it also. I installed it (leaving the MPTK uninstalled) and I get the same error.
EDIT #2: Just read up on the Avid site that the mptk1 is only compatible up to 8.0.3... Pack of wankers Still doesn't explain why it didn't work when I was ON 8.0.3
I'm running Pro Tools LE 8 on Windows 7 Enterprise (32bit), and after installing the
MPTK just there, it hangs at "loading pro tools" perpetually. I wasn't sure exactly what
was doing it at first because I installed a few other things in the same go. After
removing (one by one) everything, I found that once I removed the MPTK, Pro Tools
started working again. I re-installed the toolkit and it stopped once again.
I was on 8.0.3 but updated to 8.0.5 in an effort to fix the issue but it still freezes.
Any ideas? I need to be able to use the MPTK, especially considering I own a
$%&*%@ license
Cheers
PS: Still can't get used to the new look of this place. Kinda threw me off the site.
$%&*%@ license
Cheers
