G
grinder
I have a problem with my bass, in that when I play a little harder, the low end becomes overwhelming, especially on the B and E strings. The problem is mostly caused by my inconsistant and uncontrolled playing technique, mainly during fast passages. I'm working on my technique, but was also thinking that I could my multiband might help control the problem. I'm also trying to learn how to use my multiband, so I'm trying to kill to birds with one stone. So tell me if I'm miss understanding how it works. I was thinking use the low shelf on the multiband, set with a negative gain make up, at a frequency, maybe around 125hz. I would set the threshold, so it kicks in just on problem notes. Am I on the right track here? Again, I realize that learning to play properly, is the best solution, but until then, am I thinking correctly?
Thanks, Grinder
Thanks, Grinder
Go for it. Be prepared to adjust the crossover frequency until you get it right.
(no let me say) reduction on those really dynamic parts without it being too obvious. you'll start to compress sooner to smooth out your dynamics without crushing your sound.
