Like I said in the other thread, I use
a GT-8 and much prefer it over the single stomps. Mainly because you can put it in 'manual mode' and use it like separate stomp boxes, but mainly because the GT-8 is BY FAR the most flexible multi unit available and to me sounds great. Once you get over the dang learning curve (which actually took me a good 10 hours or so to get REALLY comfortable with the unit), it is easy to operate. The fact that you can tweak to get just about most things you might currently want is why I like it. If you want just clean and overdrive, then by all means, get a nice Marshall and use the volume knob on your axe. I use the thing in a church setting too, so getting a large variety of sounds at ANY volume is a major plus too.
Personally, comparing the thing to pedals, I think sounds easily as good, if not better than your typical stomper. I have never really gotten into the boutique pedal thing, spending $300 for a one trick pedal...or more, so I can't comment there. But the reverbs, OD, delays, chorus (hey, it's a Boss) ...etc...all sound as good is any of that Digitech stuff, or whatever flavor you like. Same with the wahs.
No...I don't use the "slicer"..the appegiator, and some of that "off the wall stuff"...but the feedbacker is pretty insane, as is the tone modifier, dual amps sounds at once, dynamic mode.....
I figure the $500 beans isn't all that more than a couple or three pedals or so... unless you're buying that DanElectro garbage. ...nevermind that "Bad Monkee" people rave about. My "Bad Monkee" went back the next day
Still got my whammy wah though and
the ProCo rat. For a quick "throw some stuff in the back seat of the car" kinda setup, they work. The GT-8 does the same thing in spades.. and more.
so...you think Roland will give me a job now
