Started TRYING to get the thing setup last night... Did all the Windows updates and got the driver updates for the MultiMix... Was looking at using N-Track since it's almost as cheap as I am and the Cubase LE, with it's 4 inputs at time recording on a 16 channel mixer/recording interface is about as useless as tits on a boar hog... With N-Track I had to update to .NET 2.0... Well guess what, the MultiMix drivers off the web ONLY work with .NET 1.1.something or another...
Used the drivers from the CD and got the MM loaded.. Everything went as it said it would in the book...
Installed N-Track and it cranked up fine, but I never could get it to recognize the MM and it locked up everytime I tried to get into the Preferences (guess this is where I go make hardware selection and adjustments).
Installed Cubase LE to see if it would work any better... Problem ONE.. After going through the Cubase install all the way to hitting the Finish button and the Windows Installer closing, when you try and close the Cubase installation selection screen I as told that the installation was incomplete and if I close now it may not work...
From there it all went downhill...
Opening Cubase for the first time I got a little popup window wanting to TEST something.. Ran the test and everything locked up so hard I had to pull the power plug and battery to shut down and reboot.
Once rebooted w/ the MM16 on starting ANY application would cause program locks. You could shut the programs down this time though. Rebooted again with the MM16 off. Turned the MM16 on and started Cubase again and it all went in the gutter again.
Reboot one more time with the MM16 off, open Cubase, changed the clock source to the Alesis and THEN start the MM16...
All seems Ok right now except only being able to select 4 channels to record from at a time... Not to sure it's entirely stable though. Haven't tried to put even the first sound trough the thing to see if it's going to actually record at this point.
Would LIKE to be able to get the updated drivers for the MM off the web to work with .NET 2.0, so I'll prolly be buggin' the begeebees out of Robert Ray with Alesis later today
And because I'm so cheap I'm gonna try and go back with N-Track
Rob
