you might wnat to try and reformatt your cf card.... should resore it to its original form....
i was speaking about recording in extended mode...
to burn a cd the bit rate must be 16 bits...this is the normal setting
if you use extended the only thing you can do is move it to a cassette tape....
the bit rate is too small, wont burn to cd....
