MR8 help needed
spin_doctor
I was here a while back about the hard disk in my MR8. It was suggested that I replace the disk which I did (same exact HD). After exchanging the units I placed the unit in disk format mode which continued and continued for 72 hours. I finally shut it down and put the old disk back in which worked pretty good for a while. Now, all of a sudden, when I try to record I'm getting a horrible pumping sound and some digital chatter. I have once again switched the units but it's been 24 hours with no end. Am I doing something wrong here. I know I connected it correctly so that isn't the issue. Please help if you can.
Have you checked that the jumpers on your new drive are set exactly the same as the drive you removed ?
