69ShadesofRed
OK, I have a dillema that I hope someone will give me a sound advice on.
I have a pair of Mackie HR824s. They are sitting on my desk, but I am thinking of getting some pads to lift them. As they are right now, the tweeters are about ear height, and in my normal sitting position the monitors and my head are equidistant. The thing is, in this position, I have a feeling that I am getting some serious bass buildup (my synth/workstation, is right infront of the monitors). When I crouch a little so that my ears are about in-between the tweeters and woofers, I hear less bass. But at the same time I hear some major timbral shifts in the mids and highs as well. The problem is, I am not quite sure which position sounds accurate.
So my question is, what's the method for finding the correct monitor position that sounds accurate... and most importantly, how do you know what you hear is accurate w/o any specialized tools?
I also hear/read conflicting theories on monitor positioning. Some sources say that the tweeters should be the same height as the ears, even if you have to position monitors sideways or upside down. Other sources claim that the ears should be about mid level between the tweeters and the woofers. Also, some say that the monitors should be angled down or up, or not.
Can someone please shed some light on this madness? Right now, my mixes are hit or miss, some translate well, some sound like shit, and it's mostly because I hear different things w/minor changes in my listening position.
Thank you.
Thank you.
