TAPESOURCE
Hi,
I'm a newbie here,
It's been 3 years now that i own a Soundcraft 500 mixer and I'm pretty happy with it.
The only things i've done is recapping the entire board and the power supply, and replace the old ribbon cable by a new one.
I would like to use the desk to mix tracks that i record.
I use to work a lot with HPF and LPF, and i was wondering if there's a way to modify the fixed 100Hz HPF switch to a variable HPF potentiometer.
I made some research but haven't found anything on this.
The questions here are : Is it possible ? Is there someone here who have already done this? Is it simple ? or do i need to forget about this mod?
The other mod i would like to do is adding a polarity switch on every channels. Is there an easy way to do it?
If some of you have links to share to learn about this would be great.
Thank you!
r . 0 0 1
I'm a newbie here,
Thank you!
r . 0 0 1
