Mixing Tubes
  • Thread starter Thread starter DTBlalock
D
DTBlalock
Is it bad to mix different brands of preamp and power tubes...
12Ax7 for preamp and 6L6/5881 for power
nope, its fine.
the only thing you really want is power tubes that are matched.
H2H
Hard2Hear said:
nope, its fine.
H2H
Yep.
It's not that unusual to run different brands of preamp tubes in the same amp, but always go with same brand, matched power amp tubes in a push-pull design amp.
kid klash said:
It's not that unusual to run different brands of preamp tubes in the same amp...
"Preamp" tubes serve different functions in an amp and I find that the actual front-end "tone" tube -- the actual preamp tube -- will usually be different than the phase inverter tube in a well set-up rig. Some 12AX7s simply don't do well (and often fail) as phase inverters, but are great as preamp tubes.
