D
djdarwin
How symetrical do you guys try and keep your mixes?
Kick, Snare, Bass are smack in the middle but where do you put the High Hats?
You have a strong lead sound and just one other counter melody. Say a huge saw wave and a small piano. Is it ok to leave the saw right in the middle and move the Piano to one side ONLY so that it stands out more? Or should you double up the piano and put one on each side?
When panning should you pan things as far out as possible or leave them as close to the center as possible?
If you have 4 string parts and 4 piano parts all playing in the mid frequency should you spread them equally apart from eachother and should you start with one all the way left and one all the way right?
is perfect symetry the optimal situation?
once I chop off his head, aside from getting all his brute power and knowledge, I also get his beloved rep points...even though rep points are still gay
....hold me.
