miroslav
Cosmic Cowboy
I didn't say that though I'm definitely not an advocate of 'giving up' on panning, that's absurd. Perhaps I didn't make it clear what I meant there. Using the word 'compatability' was perhaps a mistake.
I was just going by what you said about compatibility taking precedence over panning.
Using mono to set up your mix before you go to stereo, is nothing unusual, and if you like working that way, then stick with it....however, I don't see that as any guarantee. I mean...if that was some sort of absolute, then everyone would be doing it...first mono then stereo.
I also don't agree that a mix, set up in mono, will just pan out, and it sounds great, and you're done.
Every move triggers a reaction. So going from mono with everything stacked up the center...and then panning out to a full stereo stage...is like night and day AFA how it sounds and what it needs.
Lowering a track in mono to make it sit right in the mono mix, will not sound the same when panned out.
OK, maybe you like what happens to the sound when you do that...I'm just saying the level balances are going to be different, processing will be different, FX will be different...etc.
Yes...monitoring in mono will accentuate certain things, and that can make you aware of issues or certain imbalances...but it's not some trick that makes everything sound better....IMO, YMMV.
So we come back to the real point.
Who are you mixing for...?...the odd listener who happens to hear it in mono or the bulk of listeners who will hear it in stereo? Not to mention, if it's your stuff, you would want to first please yourself in your production goals, I would think...and if you want to hear a mix a certain way, that IMO takes precedence over worrying about the many, many listening environment that exist, and trying to deliver equally to all.
There are only some mixes that can *equally* straddle a mono or stereo image and sound deliver and equally good listening experience. It's not just a twist of the pan knob...IMO.
Anyway...it's a good discussion, and it makes sense that people try out different approaches in their mixing, if for no other reason, simply to discover new possibilities and ways of listening to their mixes.
If you get around to it...post up some A/B...just so we can hear what you've been hearing with mono VS stereo.
