Recording guitars
Okay.... here is my pet-peeve in this statement right here. "Too much distortion"... UGH... I have been playing and recording for 30 years and every time an engineer tells me that, I want to bean him across the head with my FX board. Guitarist, for all of their quirks, have worked on their sound and have found the sound that they like and that defines them. Asking them to change their sound to accommodate the engineers inability to record what he hears is no different then telling a drummer he has to play softer because he's causing distortion from the mics (I've had that happen). If we reduce our distortion to please the engineer or the producer, then we don't have the sound we want and we won't be happy with our work, because it will not be our sound, it will be the engineer's sound, the producers sound. As guitarist, we know our gear that is our yard. As an engineer, you know or should know your gear and how to use it, that's your yard. Stay out of my yard and i'll stay out of yours. You may look over my fence and tell me there is a better way to cut the grass, but I like the way I cut my grass and you don't know my lawn mower. Now if you want to use my mower, I'm going to advise you the best way to use it for the best results. Dig?
WHAT you hear coming out of the amp is what you should hear coming out of the control room speakers. If you don't, it's not the guitar players problem, it is the engineers problem.
Now to your recording issue..... Re-record the guitar track with your sound as you like to hear it coming from your amp. MIC it about 2 feet from the speaker cab, set your eq on the board to all flat, reduce your input gain. Remove any and all effects at the board, your effects should come from your guitar gear, not something processed at the board.
If you are using your line-out from your amp, don't. Regardless of what they tell you, it overdrives the input signal into the recording gear and gives you a "fuzzy" sound.
If you are using a Boss, Digitech or some other type of floor pedal board for your guitar effects, most of these have a USB port. Connect this unit to your computer, plug into your amp like you normally do. Change your output on the pedal board from the modeled amp you may have it set for to Line/headphone out. This is an internal control that you select. Now what you are doing is basically running your guitar sound with the pedal board direct to the recording software. Your PC or MAC and software should all say "Hey, you've connected a Boss GT-10, let me make that part of the gear available".... and tada! It should be nice and full with no recording "fuzzy-ness", I know, because I do it all the time.
This message brought to you buy an old guy who's been doing this crap a long time. Peace and all that.... TK
Without hearing it, I can only give you guesses as to why it isnt working.
1. Too much distortion. This with give you a fuzzy mess that doesn't let you hear what the guitar is playing. You need to dial in a crunchy sound, not a fuzzy one.
2. Scooping the mids. Guitars are a midrange instrument, if you scoop out all the mids, all you are left with is mud and hiss. That isn't what will cut through a mix and sound agressive
3. Copy and paste. You actually need to play the part twice in order to create stereo by panning them apart. Copy/paste doesn't work.
You need to post an mp3 of what you have. Then you will get specific recommendations for your situation.
